Plastic gears are everywhere
Chapter 2, Continued
In the previous sections, development of conjugate, face milled as well as face hobbed bevel gearsets - including the application of profile and length crowning - was demonstrated. It was mentioned during that demonstration that in order to optimize the common surface area, where pinion and gear flanks have meshing contact (common flank working area), a profile shift must be introduced. This concluding section of chapter 2 explains the principle of profile shift; i.e. - how it is applied to bevel and hypoid
gears and then expands on profile side shift, and the frequently used root angle correction which - from its gear theoretical
understanding - is a variable profile shift that changes the shift factor along the face width. The end of this section elaborates on
five different possibilities to tilt the face cutter head relative to the generating gear, in order to achieve interesting effects on the
bevel gear flank form. This installment concludes chapter 2 of the Bevel Gear Technology book that lays the foundation of the following
chapters, some of which also will be covered in this series.
In the previous sections, the development of conjugate bevel gearsets via hand calculations was
demonstrated. The goal of this exercise was to encourage the reader to gain a basic understanding of
the theory of bevel gears. This knowledge will help gear engineers to better judge bevel gear design
and their manufacturing methods.
In order to make the basis of this learning experience even more realistic, this chapter will convert
a conjugate bevel gearset into a gearset that is suitable in a real-world application. Length and profile
crowning will be applied to the conjugate flank surfaces. Just as in the previous chapter, all computations
are demonstrated as manual hand calculations. This also shows that bevel gear theory is not as
complicated as commonly assumed.
This article is the fourth installment in Gear Technology's series of excerpts from
Dr. Hermann J. Stadtfeld's book, Gleason Bevel Gear Technology. The first three
excerpts can be found in our June, July and August 2015 issues.
In the previous chapter, we demonstrated the development of a face-milled spiral bevel gearset. In this section, an analogue face-hobbed bevel gearset is derived.
The calculation begins with the computation of the ring gear
blank data. The geometrically relevant parameters are shown in Figure 1. The position of the teeth relative to the blank coordinate system of a bevel gear blank is satisfactorily defined with...
The question is quite broad, as there
are different methods for setting various types of gears and complexity of
gear assemblies, but all gears have a few things in common.
