Large, multi-segmented girth gears do not behave like the relatively compact, rigid, monolithic structures we typically envision when discussing gear manufacturing. Girth gears are very large, non-rigid structures that require special care during the machining of individual mating segments as well as the assembled gear blank itself.
Multiple possibilities are available to increase the transmissible power of girth gears. These solutions include: using a larger module, increasing of the gear diameter through the number of teeth, enlarging the face width, and increasing the hardness of the base material. The first three parameters are mostly limited by cutting machine capability. Module, outside diameter, and face width (for a cast gear) can theoretically be increased to infinity, but not the cutting machine dimensions. There are also practical limits with respect to the installation of very large diameter/large face width gears.
Let's talk about large gears. Not the size or scope or inspection process, but the forecast and market potential in areas that utilize
these massive components. We'll examine key industry segments like energy and mining and tap IHS Economics for a forecast for 2016 and 2017 (spoiler alert: it's not great). Additionally, we'll discuss some of
the critical factors influencing global big gear manufacturers Ferry-Capitain and Hofmann Engineering.
Environmentally friendly, highly efficient and lasting a product's lifetime. With characteristics like this, Pulsed-Plasma Diffusion (PPD) technology from Oerlikon Balzers has established itself as an industry standard for the treatment of large automotive press tooling. Now the technology specialists are targeting new applications with this advanced process, offering an alternative to traditional hard-chrome processes.
Much of the existing guidelines for making large, high-performance gears for wind turbine gearboxes exhibit a need for improvement. Consider: the large grinding stock used to compensate for heat treatment distortion can significantly reduce manufacturing productivity; and, materials and manufacturing processes are two other promising avenues to improvement. The work presented here investigates quenchable alloy steels that, combined with specifically developed Case-hardening and heat treatment processes, exhibits reduced distortion and, in turn, requires a smaller grinding stock.
