The large gears found in mining, steel, construction, off-road, marine and energy applications—massive and
robust in nature—need to tackle the greatest production demands. This, in turn, means that a special emphasis must be put on the heat treating methods used to increase the wear resistance and strength properties of gears this size.
In the wide, wide world of moving
parts, the gears required for the big
jobs—the really big jobs—often experience big problems. Proper lubrication of these gears is paramount in industrial applications such as wind turbines, kilns, sugar mills, crushers, heavy construction, offshore drilling rigs, mining and quarrying.
Indexable carbide insert cutting tools for gears are nothing new. But big gears have recently become a very big business. The result is that there's been a renewed interest in carbide insert cutting tools.
The complete product news section from the January/February 2009 issue of Gear Technology, featuring giant-sized David Brown girth gears, gear inspection up to 4.5 meters and the latest Gleason gear grinder.
