At the dawn of the Industrial
A finite elements-based contact model is developed to predict load distribution along the spline joint interfaces; effects of spline misalignment are investigated along with intentional lead crowning of the contacting surfaces. The effects of manufacturing tooth indexing error on spline load distributions are demonstrated by using the proposed model.
Involute spline couplings are used to transmit torque from a shaft to a gear hub or other rotating component.
External gear teeth on the shaft engage an equal number of internal teeth in the hub. Because multiple teeth engage
simultaneously, they can transmit much larger torques than a simple key and keyway assembly. However, manufacturing
variations affect the clearance between each pair of mating teeth, resulting in only partial engagement.
