I received a letter from Mr. G. W. Richmond, Sullivan Machinery Company, N.H., in which in addition to correcting
mistyping, he made several suggestions
concerning my article "General Equations
for Gear Cutting Tool Calculations."
shafts.
the same heat of material
One of the current research
