For many, the best alternative is to identify a top-flight commercial treater that will work closely with you and your manufacturing process. Also, look for a commercial house that insists that customers invest in to-the-print tooling before they’ll agree to take on a job.
Bodycote, an international heat treating provider, is one of them.
“We require (dedicated) tooling for each job, and we’re not going to use something that’s ‘close enough,’” says Don Giessel, general manager at Bodycote’s New Berlin, WI plant.
“We take the stance that (the customer) must use the proper tooling for the proper job. Otherwise, they may come back to us and say ‘This isn’t flat enough,’ etc., because of improper tooling.”
Of course, there are other considerations at play when seeking out a good commercial heat treater. Bob Lacock, marketing manager for commercial heat treater Solar Atmospheres in Souderton, PA, addresses some of the more important ones.
Xtek specializes in carburizing heavy equipment gears for its customers.
“The primary goal of successful outsourcing is to decrease costs (purchasing, overhead, personnel, maintenance and processing),” he says. “Complementary to reducing costs is to give management more time and resources to focus on core activities. Outsourcing also allows for production flexibility; that is, expanding without investing in capital equipment and other associated costs. Conversely, savings occur when there is no idle equipment or people during slower production times.”
As mentioned, capabilities can be a huge difference maker, particularly with gear manufacture. Vacuum caburizing, for instance, is one of the newer technologies to come along. It is a much cleaner and cost-effective process in that the part comes out of the furnace in a much cleaner and finished state than with older heat treat processes. Thus with less handling and processing—less cost.
“Solar offers vacuum carburizing for optimum case-hardening results,” says Lacock. “This includes a more uniform case depth, no intergranular oxidation due to the controlled vacuum environment, and minimized distortion.” Bodycote is another commercial house providing this service.
That said, what should a gear maker look for if outsourcing is the process of choice?
“No. 1, a heat treater that’s going to work with them in the gear manufacturing process,” says Bodycote’s Giessel. “It’s very important that (the treater) ask a lot of questions; if a gear manufacturer calls up and asks someone about their heat treating their gears and all he gets is pricing, that should be a red flag. A lot of questions need to be asked upfront. No. 2, with press quenching, be adamant that proper tooling be used for that job, and don’t settle for the existing tooling of another treater’s customer whose tooling is just close.”
As for Solar, Lacock says it’s all about “Honesty, plus unique capabilities, responsive service and consistent quality. And having staff metallurgists and an R&D department as we do at Solar.”
And the winner is…So who to call—captive or commercial? The fairest answer is that there is no clear-cut winner in this debate.
Commercial houses may have more equipment capabilities, metallurgical and heat treat expertise, and, depending on the project, faster turnaround.
And yet gear makers—especially those with advanced heat treat facilities—possess an understanding of gears that most, although as this article certainly demonstrates, not all, commercials can’t begin to match.
But one contention can be held that is impossible to argue against: If you are a maker of highest-precision gears, you must have a trusted and experienced provider—in-house or commercial—for heat treating for gears.
Anything short of that is playing with fire.
For more information:
Don Giessel
General Manager
Bodycote Thermal Processing
16167 West Rogers Drive
New Berlin, WI 53151
Phone: (262) 782-5553
E-Fax: (262) 782-5660
E-mail: don.giessel@bodycote.com
Trevor Jones
Solar Atmospheres
1969 Clearview Road
Souderton, PA 18964
Phone: (800) 347-3236
Fax: (215) 723-6460
E-mail: tmj@solaratm.com
Website: www.solaratm.com
Xtek Inc.
11451 Reading Road
Cincinnati, OH 45103
Phone: (513) 733-7802
Fax: (513) 733-7939
E-mail: Kevin.biggers@xtek.com
Website: www.xtek.com
