CoroMill 490 Offers 10 mm Depth
The Sandvik CoroMill490 is a milling cutter that can shoulder mill, face mill, edge, contour, slice, slot in all materials, and the latest version of it can take up to 10 mm depth of cut.
The 13 mm insert is designed for larger depths of cut and engagements up to 10 mm. The new insert size is included as part of an expanded program of cutter bodies in diameter range 40 to 250 mm and in grades and geometries for steel and cast iron machining.
