Technical
Design of High Contact Ratio Spur Gears Cut With Standard Tools
In high precision and heavily loaded spur gears, the effect of gear error is negligible, so the periodic variation of tooth stiffness is the principal cause of noise and vibration. High contact ration spur gears can be used to exclude or reduce the variation of tooth stiffness.
This article appeared in the July/August 2003 issue.
