ECM Offers ICBP Jumbo Furnace Line
ICBP Jumbo is the latest ECM solution design for the low pressure carburizing furnace range. It maintains all the compact and modular qualities of the ICBP Flex design but goes further in terms of volume and number of parts treated in a low pressure carburizing installation. The major points of the ICBP Jumbo: It can accommodate up to 12 cells in the same row, it is fully compatible with all versions of AMS2750E aerospace specifications, compact systems with the cells facing one another and the possibility to have gas and oil quenching on the same installation, possibility to perform maintenance from the back and the front of the cell during production thanks to rails on which the cells are mounted which make the maintenance position possible and no civil engineering additional cost. The transfer module is isolated and heated to guarantee quenching uniformity from one load to the next. This modularity guarantees the possibility to mix any type of recipe process with a continuous workflow.
