EFD Induction Awarded Orders for Induction Scanners to Harden Sun Gears and Output Shafts
EFD Induction USA has recently won major orders from two American tier-one automotive suppliers.
The orders involve EFD Induction ‘HardLine’ type induction scanning systems for the hardening of sun gears and output shafts. Each system comprises an induction scanner, a power source, and various optional features.
The first order comprises an EFD Induction Rotary Table (HardLine RT 550) hardening system for treating sun gears, and a vertical scanner system (HardLine VM 1000) for hardening output shafts.
The second order is for two vertical scanner systems, a HardLine VS 300 for hardening sun gears, and a HardLine VL 1000 for treating shafts.
All the systems are powered by EFD Induction Sinac power sources, and feature CNC-based control systems. Each machine also features a closed-loop cooling system. HardLine is EFD Induction’s family of systems for surface and through-hardening, with equipment available to handle everything from small gears with complex geometries up to the giant slewing rings used in modern wind turbines. The vertical scanners supports a range of optional subsystems, including: automated loading/unloading solutions, indexing tables with unlimited position control, double tailstocks and centers for the simultaneous hardening of two workpieces, a HF/MF chuck connection for quick changeovers between high and medium frequencies.
The hardening system can also be paired with an integrated or separate tempering station.
