EMAG Eldec Induction Hardening Systems Offer Precision Hardening, Lower Power Consumption
EMAG subsidiary Eldec has developed modular induction hardening systems. The technology ensures efficient processes that integrate hardening into component production lines, even at supplier companies, improving operative excellence.
The systems introduce heat into the workpiece through induction, meaning only the areas to be hardened are heated.
"This is an initial crucial factor," emphasizes Stefan Rechtacek from technical sales at Eldec. "This allows the energy level to be precisely metered. The induction hardening process takes less than a second, depending on the component. Power consumption, of course, falls significantly as a result."
In comparison, case hardening furnaces are mostly heated around the clock (even when no components are in it), while induction hardening machines are only in use precisely when required. Even small batches can be quickly and flexibly hardened.
Ultimately, however, it comes down to the optimized configuration of the machine, the tools and their power source. For this reason, Eldec machine designers extensively advise customers from the beginning, where the application area of the gear and the resulting level of hardness play an important role.
"In our test lab we initially check to see if induction hardening is fundamentally suitable for the desired component, what processes are required for the hardening and what unit costs the user can ultimately expect. This creates an ideal basis for making an informed decision," Rechtacek explains.
