EMAG Eldec Modular Induction (MIND) Hardening Systems Offer Flexibility and Simplicity
EMAG subsidiary Eldec has developed new modular induction hardening systems designed to simplify the gear hardening process and increase flexibility in the overall production workflow. The company continues to refine its process, which introduces heat into the workpiece through induction. Only the areas to be hardened are heated.
"This is an initial crucial factor," emphasizes Stefan Rechtacek from technical sales at Eldec. "This allows the energy level to be precisely metered. The induction hardening process takes less than a second, depending on the component. Power consumption, of course, falls significantly as a result."
In comparison, case hardening furnaces are mostly heated around the clock (even when no components are in it), while induction hardening machines are only in use precisely when required. Even small batches can be quickly and flexibly hardened.
Ultimately, however, it comes down to the optimized configuration of the machine, the tools and their power source. For this reason, Eldec machine designers advise customers from the beginning, where the application area of the gear and the resulting level of hardness play an important role.
"In our test lab we initially check to see if induction hardening is fundamentally suitable for the desired component, what processes are required for the hardening and what unit costs the user can ultimately expect. This creates an ideal basis for making an informed decision," Rechtacek said.
The Eldec Modular Induction (MIND) system, with its key components consisting of the basic machine, power source, inductor, coolant system and automation, forms the centerpiece of the subsequent machine configuration. Each of these components is adapted to the required process. For example, micro-process-controlled high-frequency and medium-frequency generators, as well as simultaneous dual frequency (SDF), are available with eldec. While medium frequencies generally penetrate deeper into the gear and, in particular, heat the root, high frequencies heat the tooth tip. Subsequently, SDF employs two different frequencies simultaneously on the workpiece, heating to an even depth and temperature.
