EMO Hannover Preview: Grind Master
Grind Master offers a wide range of belt grinding and brushing machines which are used for precision deburring of flat punched and fine blanked parts like clutch plates, discs, sector gears, brake pads, bearing thrust washer and sintered parts like stator, rotor, cover plate, distribution plate of common rail pump, fuel injection parts, valve plates of compressors etc.
These machines are offered with multiple belt grinding heads and planetary brushing heads depending on the amount of burr and customer requirement of deburred edge, finish and micro radius. The new platen type belt grinder ensures the flatness on the parts.  The machine can deburr even non-magnetic small parts.  This process improves the surface contact area of flat parts which is important for parts like engine thrust washers.
These are very robust and rugged machines equipped with PLC logic control system, magnetized conveyor, inline demagnetizer, and an auto load and unload system.
Grind Master also offers a NanoFinish range of machines for superfinishing of automotive powertrain, transmission, suspension and steering parts trusted by leading OEMs globally.
NanoFinish Model SMP1000 is built to achieve both size and finish in one process. Achieving stock removals of up to 20 microns, the machine guarantees output size within ±5 microns, at the same time achieving fine finish values of Ra 0.1. Combined with hard turning technology, NanoFinish with Size Control eliminates the need for expensive and maintenance prone grinding operations. This breakthrough technology will be showcased by Grind Master in EMO Hannover in 2019 at Hall 11, Stand G22.
Nanofinish superfinishers are Industry 4.0 enabled smart machines, recognized as reliable for finishing of automotive transmission, suspension and steering parts. Equipped with the proprietary NanoFinish Control System that provides a simple and user-friendly screen for easy and quick set up change, the machines are very flexible and suitable to handle a wide range of parts. The various superfinishing parameters can be easily set on the screen of this system thereby achieving the finishing results at optimum cost.
