Face Mill Withstands Heavy-Duty Operations
The CoroMill 360 from Sandvik Coromant is a 60-degree face mill constructed with through-hardened steel for strength in demanding applications. The cutter inserts are wedge clamped with a quick release for cutting to depths of .709" or 18 mm with high feed per tooth. They are housed in an exchangeable cassette system with precise location to ensure cutter accuracy. The inserts have four edges with wide parallel land and strong edge geometry for high surface finish quality, giving a light-cutting performance.
The CoroMill 360 inserts are available in 19 mm and 28 mm, and both sizes use the same cutter body to minimize tool inventory. They can be easily removed by turning a wedge screw. They come in diameters from 160-500 mm in close and extra close pitch design as well as Arbor and CIS Arbor shank styles.
