Warning: getimagesize(https://ik.imagekit.io/agmamedia/gt/images/article_legacy_id_11831_featured_image.jpg): Failed to open stream: HTTP request failed! HTTP/1.1 404 Not Found in /home/nbd2496/geartechnology.com/article.php on line 101
Warning: Trying to access array offset on value of type bool in /home/nbd2496/geartechnology.com/article.php on line 102
Warning: Trying to access array offset on value of type bool in /home/nbd2496/geartechnology.com/article.php on line 103
Fanuc Introduces New M-1000iA for Heavy Products
Fanuc America and ROBOMACHINEs has introduced the new M-1000iA robot capable of handling very heavy products including automotive components, construction materials and battery packs for electric vehicles.
The M-1000iA’s serial-link construction gives the robot a wider range of motion in every direction.  It can extend its arm upright or rotate it backwards, which is not possible for typical heavy-payload robots with a parallel-link mechanism.  With a 1000 kg payload, a 3,253 mm horizontal reach, and a 4,297 mm vertical reach the M-1000iA is ready to go to work for manufacturers looking to increase output and maximize their production line’s efficiency.
“The new M-1000iA is Fanuc’s largest serial-link robot to date,” said Eric Potter, general manager of Fanuc America’s General Industries and Automotive Segment. “Customers that process very heavy parts need more versatility in the workspace, and this robot is a great solution for a variety of applications such as drilling and handling large automotive components, processing and handling battery packs for electric vehicles, fabrication and handling of construction materials, and much more.”
Powered by the Fanuc R-30iB Plus Controller, the M-1000iA offers the same intelligence and reliability that Fanuc robots are known for, including integrated iRVision, force sensing and Zero Down Time (ZDT).
