Fixtureworks One-Touch Manual Clamps Designed to Eliminate Need for Tools for Applying Clamping Force
Fixtureworks is now offering an extensive new lineup of One-Touch manual clamps.
One-Touch clamps offer easy and efficient clamping and unclamping of a workpiece in one simple operation. Each clamp is designed to eliminate the need for tools when applying the clamping force and helps reduce setup time and increases productivity. The lineup of One-Touch clamps includes swing, push, pull, retractable, thrust, snap and side clamps in a wide range of clamping force.
Swing clamps operate by rotating the handle, which simultaneously swings the clamp arm over the workpiece into the clamping position. Further rotation of the handle draws the clamp arm down and applies direct downward force on the work piece. The swing clamps are available with cam, adjustable and spiral-acting handles. The clamping forces applied by these swing clamps range between 170-2,250 lb.
Push clamps are designed to exert pressure against a strap clamp or work piece by rotating the handle, which then forces the center piston to extend out. Simply rotating the handle in the opposite direction retracts the center piston. Push clamps can exert forces of up to 890 lb. and can be utilized in either a vertical or horizontal position.
Pull clamps are available in two different variations, both of which operate in conjunction with a clamping pin or clamping screw to provide quick and secure fastening in repetitive operations. By rotating the handle, the clamping pin or screw is retracted into the clamp, properly locating and holding the work piece in place. The amount of clamping force ranges between 200-1,800 lb.
One-Touch clamps include: retractable versions with a clamping force of up to 945 lb. that pivot completely away from the workpiece for easy loading/unloading; thrust clamps with a clamping force of up to 315 lb. that feature a clamping body and bar used together for a range of workholding options; and snap clamps with a clamping force of up to 31 lb. that provide a unique snap-on system. Once the handle is moved forward, the internal mechanism works to build tension. At a specific point, the tension is released and transformed into clamping force.
The One-Touch side clamp has a moving jaw that pivots forward and downward to securely hold the workpiece. The One-Touch side clamp, which has a clamping force of up to 900 lb., uses a handle to engage the clamping jaw. Other variations feature double jaws and built-in work supports. Side clamps are designed to apply workholding forces to the side of a workpiece, leaving the top free of obstructions during the machining process. In addition to the One-Touch clamps, Fixtureworks offers Fairlane Products' full line of grippers, rest pads, Swivots swivel/pivoting positioning components, quick release ball lock pins, rollers and bumpers, Kipp spring plungers, rest and riser pads, levers, handles, knobs and handwheels, Imao clamps, mini-clamps, supports and stops, risers, T-nuts, sliding mounts, springs grid plates and blocks, OK-Vise single and double wedge clamp designs and Modern Industries mPower product line, which includes quick change precision locating and mounting systems and modular tooling, plates and columns.
