Manufacturing Processes Grinding Technical Helical Gears
Gear Grinding With Dish Wheels
The grinding of gears with dish wheels (Maad type grinding machines) is widely viewed as the most precise method of gear grinding because of the very short and simple kinematic links between the gear and the tool, and also because the cutting edges of the wheels represent planar surfaces. However, in this grinding method, depending on the parameters of the gears and one of the adjustments (such as the number of teeth encompassed by the grinding wheels), so-called overtravel at the tip or at the root of the teeth being ground generally occurs. When this happens, machining with only one wheel takes place. As a result, the profile error and the length of the generating path increases while productivity decreases.
This article appeared in the September/October 1999 issue.
