Grieve Introduces No. 814 Cabinet Oven
No. 814 is a 500 degree, electrically-heated cabinet oven from Grieve, currently used for various plastic and metal part heat treating operations at the customer’s facility.
Workspace dimensions of the oven measure 22” W x 21” D x 85” H. 18 kW and are installed in Nichrome wire tubular elements to heat the oven chamber, while a 750 CFM, 3/4-HP recirculating blower provides a vertical downward airflow to the workload.
This Grieve cabinet oven features 4-inch insulated walls, aluminized steel exterior and interior, three integral metal shelves, plus all safety equipment required by NFPA Standard 86 for handling flammable solvents, including a powered forced exhauster, airflow safety switch and purge timer.
Other controls on No. 814 include a fused disconnect switch, digital temperature controller and manual reset excess temperature controller.
