Hannover Messe Preview: Essential Power Transmission Pvt. Ltd.
Esenpro, a brand of Essential Power Transmission Pvt. Ltd., is a manufacturer of industrial gearboxes and open gears. Esenpro has multiple institutions globally in the steel, cement, plastic, mining, power, overhead cranes, port, and chemical industries. The company offers in-house designing, machining, gear grinding, metrology, calibration, and heat treatment facilities.
Esenpro offers its products both in standard and customized categories.  Esenpro standard gearboxes are helical gearboxes, bevel helical gearboxes, worm gearboxes, crane duty gearboxes, cooling tower gearboxes, extruder gearboxes, rolling mill gearboxes, and aerator gears and gear assemblies. They also offer open gears per customer design and special gearboxes for crane, power, steel, paper, and mining industries.
Esenpro also undertakes re-engineering of existing/old gears and gearboxes, for any plant and machinery to enhance their capacity, to withstand higher speed, feed, and load within the existing mounting dimensions. Esenpro also designs and supplies drop in replacement gearboxes. These gearboxes exactly replace the old gearbox without an inch of modification to the existing foundation. Further to the existing range of products, Esenpro has a separate engineering team to develop planetary gearboxes for steel, power, sugar, material handling and mining.
The company will be presenting these technologies at Hannover Messe 2019, Hall 25, Stand B08/1 from April 1-5 in Germany.
