Lubrication Coatings Technical
Hard Gear Finishing with a Geometrically Defined Cutting Edge
The market demand for gear manufacturers to transmit higher torques via smaller-sized gear units inevitably leads to the use of case-hardened gears with high manufacturing and surface quality. In order to generate high part quality, there is an increasing trend towards the elimination of the process-induced distortion that occurs during heat treatment by means of subsequent hard finishing.
This article appeared in the November/December 1999 issue.
