Helix Unveils Miniature Linear Guidance Products
This new family of linear guidance products from Helix offers precision, accuracy and flexibility, and consists of an embedded inverse hook design. It’s designed to tightly secure block components, which in turn helps them to better handle impact forces as they work to distribute stress over a larger area of the system.
Linear guidance systems offer accurate positioning, are often high speed and energy saving and can maintain accuracy for long periods of time in their respective applications.
Additional benefits of the Helix Miniature Linear Guides include:
Unique design: The miniature guides consist of a ball re-circulating design along with an embedded inverse hook design, which helps to reduce noise while at the same time extend life, reduce maintenance and improve high speed running capability.
Reinforced plates: The HMR-EE series stainless steel reinforced plates help to make this product line able to handle the operation of high running speeds.
Lubrication: Included in the design is an embedded lubrication pad, which works to oil balls and the raceway.
Greater surface contact: This feature allows the miniature guides to work with high load and high moment capacity when compared to competing products.
Dust-proof: Designed so that dust contamination is restricted, thereby enabling prolonged life.
