Inspection Metrology Product News Industry News
Hexagon Metrology Releases PC-DMIS Gear
Hexagon Metrology announces the release of PC-DMIS Gear 2.5, a sophisticated software module, designed for basic and advanced gear measurement applications. The new version simplifies measurement routines by using a parameter-driven graphical interface to speed inspections of helical spur, bevel gears and pinions. PC-DMIS Gear 2.5 software is compatible with standard CMMs, eliminating the need to invest in separate gear measurement equipment. The software also runs on vision CMMs for inspection applications of small spur gears. PC-DMIS is an integrated metrology system used for developing inspection routines, measuring parts, managing data, evaluating and reporting results.
Expert and non-expert operators can quickly build gear inspection routines, by first completing a rules-driven form, then choosing the desired inspection report(s) from a set of pre-defined, standard formats. The software then automatically generates the program and inspection reports. Users can also create measurement alignment and probe qualification routines to completely automate the inspection process. Gear supports a wide range of international standards including AGMA 2000-A88, DIN 3962, JIS B 1702 and ISO 1328.
Ken Woodbine, president of Hexagon Metrology’s software division, said that Gear is a very cost-effective inspection method as compared to expensive, dedicated gear measurement equipment. The software interface has been enhanced and simplified and even entry-level operators can run inspection routines accurately. Utilizing forms, wizards and pre-defined routines, users can calibrate probes, define datum, and measure and evaluate gears in record time.
