High-Speed Inserts Incorporate Through Coolant
The Power-Feed+Mini high feed cutter from Ingersoll Cutting Tools features high-speed geometry with a double-sided, four-edge insert engineered specifically for high-speed machining to deliver economy, strength and performance.
The inserts infuse Power-Feed+ technology into a smaller insert to provide high-feed capabilities with higher insert densities in smaller diameter end mills. The cutter bodies incorporate through coolant and are constructed of premium alloy steel materials. They are appropriate for high speed roughing at lighter depths of cut.
