Design Efficiency The Gear Industry Sectors Automotive Technical
How to Minimize Power Losses in Transmissions, Axles and Steering Systems
By increasing the number of gears and the transmission-ratio spread, the engine will run with better fuel efficiency and without loss of driving dynamics. Transmission efficiency itself can be improved by: using fuelefficient transmission oil; optimizing the lubrication systems and pumps; improving shifting strategies and optimizing gearings; and optimizing bearings and seals/gaskets.
This article appeared in the September 2012 issue.
