Hyundai WIA F500 Plus Vertical Machining Center to Be Displayed in U.S. for First Time
Hyundai WIA Machine America recently announced it will have multiple CNC machines on display at WESTEC in booth #1515. The event will be the first time the F500 Plus vertical machining center is displayed in the U.S. In addition to vertical machining, product experts will host demonstrations of the latest advances in compact CNC turning and multi-task turning centers.
The F500 Plus utilizes a high-precision, high-torque BIG PLUSR spindle in a construction that is designed to eliminate thermal growth during heavy duty cutting. Thirty-position, servo-powered tool magazines make for quick and reliable tool changes. High-speed axis travel on roller linear motion guide ways reduces non-cutting time.
The E160A compact CNC turning center's 45-degree, one-piece casting bed structure and 6" chuck are meant to provide the rigidity and strength for high-performance machining of small diameter parts. The E160A has a travel speed of 30m/min on linear motion guide ways.
The L2100SY multi-tasking wedge type y-axis CNC turning center has an 8" chuck on the main spindle and a 6" chuck on the sub spindle for complex machining in a single setup. A latest-generation BMT top plate is installed to increase tool performance and rigidity by securing each tool with four screws. Cutting is reinforced by all-axis box guideway design.
