IMTS 2016: Doimak North America (N-6698)
RER-G Combi 500 Grinding Center
At IMTS 2016, Doimak will display the RER-G Combi 500 Grinding Center with Fanuc CNC and two wheelheads. Designed for grinding OD, ID and threads, the RER-G is equipped with a fast automatic changing grinding head by means of a rotary base turret enabling multiple grinding operations in a single setup. The RER series offers a compact design, external/internal thread grinding in fully automatic transition, OD and gear grinding with optional CBN or peeling and b axis for tapers, flexible multi-task grinding, 2-axis contour dress or full form. The machine is available in a two or three wheel head design.
Additionally, Doimak recently delivered two REN-T spline and gear grinding machines for the machining of cycloid, helical and spur gears. Doimak tested and delivered these models that included integrated probing technology for gear inspection. The machine inspects gear diameter, run-out or teeth alignment just after grinding takes place, reducing machine setup times and providing a more efficient overall machining process thanks to the integrated inspection technology. The following is a brief rundown of some of Doimak's other machining capabilities:
Thread Grinding
Thread grinding machines for all types of threading technology is the product line most representative of Doimak. The latest CNC technology is implemented with built-in drives and linear motors. These machines include a wide range of spindle designs offering optimum stiffness and damping response. Any type of profile can be dressed thanks to the flexible contour dresser, which also accommodates plunge forming rolls. Multi-ribbed wheels are used for improving process productivity and mass production machines are equipped with robot or gantry type loaders. They offer a higher degree of process automation thanks to different probing and component measuring solutions.
Cylindrical Grinding
