IMTS 2016: Euro-Tech Corp. (W-2453)
Mytec Mechanical Arbors and Chucks
Euro-Tech Corporation's IMTS 2016 product lineup includes MyTec Hydraclamp expansion elements, the optimal connecting link between workpiece and machine. Now Mytec is introducing its new line of Mechanical Arbors and Chucks with accuracy down to .0004" plus high expansion rates up to .010" or greater in a stainless steel construction. Mechanical arbors and chucks are excellent for workholding where high forces are incurred or auto load applications where high clearance is required. Mytec elements feature a closed expansion system, which is absolutely impervious to dirt and chips guaranteeing a long service life.
Frenco Spline Gages
Euro-Tech's Frenco spline gage product line provides a quick method of inspecting involute splines, serration splines and straight sided splines to ensure interchangeability of parts even between different manufacturers. Frenco's INO System is an internal standard for the external dimensional measurement of spline gages developed based on national and international standards that is suited to even the most highly sensitive and complex components and systems.
Kostyrka Clamping Sleeves
Precise and long-lasting, Kostyrka slotted clamping sleeve technology is based on the idea of creating a shaft-hub joint actuated by hydraulic pressure to efficiently support the workholding function of modern machine tools which users can depend on for reliable operation day after day and year after year.
