New Tool and Servicing Solutions
Gleason will present its complete gear manufacturing tool program, including modern tool servicing concepts with integrated connectivity via RFID. Products featured will include tool materials like G90 and advanced carbides, optimized with the latest wear coatings. Power Skiving Tools are now available in solid carbide and with inserted blades for the Hard Gear Power Skiving process. For bevel gears Gleason will show the Pentac Plus RT cutter head which is designed to make blade setup and checking more reliable and faster than any current solution on the market. Gleason will also present its latest line of hard finishing tools including dressing tools for grinding and honing applications.
Advanced Workholding Solutions
Quik-Flex Plus, Gleason's next generation of modular, quick-change workholding systems requires a single tool, less time and minimal operator experience. Customers are invited to stop by and participate in the Gleason Quik-Flex Plus Challenge to experience how easy it is to change the modular components.
Gleason will also demonstrate its line of hydraulic workholding solutions. The holding force, extreme accuracy and contamination free designs are well suited for dry gear processing applications. The new Gleason Stir-Able Modular Workholding designs allow off-spindle assembly and truing, reducing changeover time as well as the amount of total run-out in the fixture.
Gleason Automation Systems with Modular, Integrated Solutions
Gleason Automation Systems specializes in the design and manufacture of factory automation systems serving a variety of customers in the automotive and other industries. Gleason will present the modularity of its automation systems with two different solutions including the compact DS1200 automation unit with integrated secondary processes as an accurate, reliable alternative to costly, operator dependent, conveyor automation. This compact system, which is compatible with most machine tools, uses robotic technology for loading and unloading. Its secondary operations capability allows this system to function as a versatile work cell, further enhancing productivity.
Gleason Global Services
Gleason Global Services is a leading source of gear technology knowhow and education. Gleason trainers will be promoting the full range of training classes ranging from beginner levels to the most advanced expert topics. Gleason Global Services will present its range of performance upgrades, modernization programs and tooling services, including practical examples.
Gleason Plastic Gears
Gleason Plastic Gears will showcase its capabilities in plastic gear design and injection molded plastic gears including bevel and cylindrical gears, helical and spur gears, planetary and internal gears. Gleason Plastic Gears provides customers with the benefit of a plastic gear with no weld-line for a stronger, more accurate and economical drive train, eliminating the additional expense of secondary machining. Our experts will be at the show to address all questions you may have.
