IMTS 2016: Hardinge Inc. (S-8738)
Hardinge Talent 51 MSY CNC Turning Center
The all-new Hardinge Talent 51 MSY CNC Turning Center will make its debut at IMTS. This machine features the Hardinge quick change Collet-Ready Spindle, which offers better part accuracy and surface finish capabilities as compared with conventional spindles. The machine also comes standard with live tooling, sub spindle and Y-axis designed to meet the most demanding machining challenges and allow for part-complete operations. The Talent 51 MSY features a 5,000 RPM 25HP main spindle with 2" bar capacity. It offers a turning diameter of 12.2" and a maximum turning length of 24.9". The 12 station turret uses ¾" square shank and 1-1/4" round shank tooling and 6000 RPM maximum live tooling capability is standard. The turret also provides ½ station index for up to 24 tools. The machine is offered with a Fanuc 0i-TF control packed with a host of standard control features.
Hardinge Conquest H51
The Hardinge Conquest H51 will be displayed with a newly released hydraulically-operated steady rest. This new attachment is the ideal tool to support long workpieces without distorting or deflecting the part. The machine features a 20hp, 5000rpm and a 2-6" main spindle with a 2" bar capacity. It offers a maximum turning diameter of 12.3" and a maximum turning length of 25.5". The 12 station turret offers ½ station index for up to 24 tools. The machine offers a wide variety of standard features such as through-tool coolant, bar feed and chip conveyor interfaces, three position stack light, PCMCIA memory card, USB Capability, rigid tapping and many others, including state-of-the-art machine crash protection.
Bridgeport XT 630 5-Axis Vertical Machining Center
On display for the first time is the new Bridgeport XT 630 5-Axis Vertical Machining Center. This new-generation machining center is a fully-digital, high-quality machine tool, designed to achieve maximum capacity and performance in the aerospace, mold and die, medical and automotive industries, as well as many other manufacturing sectors. This machine has been developed to provide a powerful and precise solution to meet the demands of the most demanding metal cutting user. Manufactured from quality sourced gray cast iron to the highest standards, the Bridgeport XT 630 5-Axis is packed with features. The machine is offered with a sophisticated yet user-friendly Siemens 840D-SL control with a 19" LCD. Axis travels are X: 762mm (30") Y: 630mm (24.8") and Z: 600mm (24"). Standard machine equipment includes Big Plus CT40 spindle, 15,000 RPM direct-coupled spindle with oil chiller, coolant chip flush system, three color stack light, 40 tool swing-arm ATC, pre-wiring for Renishaw part probe, through-ball screw chiller, preparation for through spindle coolant (with a rotary union) and A & C axis encoder.
