IMTS 2016: Luren Precision (N-6960)
LGA-2812 Continuous Generating Gear Grinding Machine for Gear Class AGMA 14
Luren brings you the all new LGA-2812 CNC continuous generating gear grinding machine. LGA-2812 is built on a Reishauer NZA, AZA machine base, utilizing an advanced Siemens Sinumerik 840D CNC controller, high speed workpiece spindle, and grinding wheel spindle. Luren's efficient generating gear grinding and impressive gear grinding results are achieved by implementing a Luren designed and created gear grinding software which acts as an interface between Luren grinding machines and the Siemens 840D controller. Minimal CNC experience is necessary to operate this machine.
Other features include a Swiss made num controller, a Windows-based operating system, an 8-axis control system, a single diamond rotary dresser and optional automation. The LGA-2812 is equipped with high speed spindles. The workpiece spindle operates up to 600 rpm. The grinding wheel spindle operates up to 5000 rpm.
Luren LFG-3540 Horizontal Gear Profile Grinding Machine for Gear Class AGMA 14
Accumulating experiences over 20 years in design and manufacturing technology of gear cutting tools as well as machine tool development, Luren Precision has developed the high-precision LFG-3540 CNC gear profile grinding machine. With a firm machine base of one-piece casting, direct drive motor with zero backlash and closed-loop optical scale for feedback control, the LFG-3540 makes high precision gear grinding a reality with a maximum capability of 400 mm in outside diameter. The LFG-3540 also has a powerful software function that allows flexible definitions of gear data and processing conditions. Fine tuning on gear profile, lead and pressure angle can be easily achieved based on measurement results. The LFG-3540 is designed to be a CNC gear profile grinding machine with one of the best performance-to-price ratio in the market.
Features include a combination direct drive motor and linear motor, special profile grinding for spur gears, pump gears and helical gears, automatic stock dividing, a point or rotary diamond dresser and on-board inspection capabilities.
Matrix Model 0550 External Thread Grinding Machine
The Matrix Model 0550 features a servo motor driven work head, a Siemens 840DE CNC control, a motorized wheel head, a coolant clarification system, automatic wheel balancing, a centrifugal separator, a programmable helix, a magnetic separator, absolute encoders fitted on all configured axes, a spindle chiller unit, a manual tailstock, a totally enclosed hood, a work head mounted dresser, a fume extraction system, a remote diagnostics system, air conditioning (ECC), one diamond dressing media, two MT work centers, one grinding wheel, one test grind (customer) part and the Matrix Profile MATE Software. Installation and commissioning is also available.
