IMTS 2016: Reishauer Corp. (N-7040)
RZ260 Gear Grinder
On the Reishauer side, an RZ260 gear grinder equipped with two work spindles will be shown off. As soon as one workpiece is ground, the turret swivels around by 180 degrees so that the machine can immediately start grinding the next part. The twin-spindle arrangement eliminates the idle time between grinding cycles. While one workpiece is being ground, the other is simultaneously meshed and oriented into the correct grinding position. To complement its range of machines, Reishauer produces its own grinding wheels, workholding and diamond dressing rolls. In this way, the company can truly guarantee that all elements of the grinding process - the machine and the tooling - are fully under control.
Customers benefit from the fact that the complete gear manufacturing process is supplied from within the Reishauer Group. If, for example, customers embark on a new project, they can rely on partners that understand all the elements that make up the gear manufacturing process; partners who can supply all the technology from machines to process parameters, grinding wheels, diamond dressing rolls, fixturing and material handling. In their field of activity, Reishauer and Felsomat guarantee the proper functioning of all these elements of the complete gear manufacturing solution.
