IMTS 2016: Speedgrip Chuck (W-2222)
Quick Change Adapter System
Speedgrip will be showing their new Quick Change Adapter System at IMTS 2016. Merging the tested and true Camlock adapter type with today's carrier and receiver system is designed to provide a solution that is accurate, fast, and affordable.
Setting up is quick. The Camlock adapter "receiver" is placed on the spindle. A receiver and retention knob retainer is attached to the jaw chuck, collet chuck and face driver and you are ready to go. To change chucks, simply release the cam studs, move the drawtube forward, remove one chuck, slide on the other, tighten the studs, retract the drawtube, and in 5 minutes you have a completely different chuck and are ready to go. Users can change from a jaw chuck to a collet chuck in less than 5 minutes, from a collet chuck to a face driver in less than 5 minutes and then back to a jaw chuck in less than 5 minutes.
The Quick Change Adapter System is more affordable than Curvic coupling quick change adapters and available in sizes A-5 to A-15. As an additional feature, the drawbar sub-assembly that can be adapted for either draw tube or drawbar.
