IMTS Preview: Okuma America Corporation
Okuma’s MA-12500H horizontal machining center will be on display for the first time at the 2014 International Manufacturing Technology Show (IMTS), Booth S-8500. The hallmark of this machine is its ability to provide a good balance of speed and cutting power for machining of aluminum alloys, cast iron and difficult-to-machine materials. This makes it well suited for large part aerospace machining. The MA-12500H is so fast and powerful, it’s the machine of choice for building lathes at the Okuma DS1 plant in Oguchi, Japan. Built on an integral bed and base, and designed with reinforcing ribs for increased stability and load carrying capacity, the MA-12500H incorporates Okuma’s exclusive Thermo-Friendly Concept to achieve unparalleled thermal stability and accuracy. Standardly-equipped with a 50 taper 6,000 rpm, 60/50 horsepower spindle, it is also available with either a 12,000 rpm wide range spindle or 4,500 rpm heavy duty spindle.
