Index Announces Next-Generation Multi-Spindle Automatic Lathe
Index has announced the launch of its next generation MS32-6 multi-spindle automatic lathe. This newest version of the six-spindle machine brings the benefits of multi-spindle technology to a broader range of applications thanks to a flexible tool slide platform that greatly reduces changeover times. The machine will be featured at Index’s global open house held in Reichenbach, Germany on April 21-24, followed by its North American debut in the company’s Booth (#338136) at IMTS 2020.
Accommodating up to 32-mm bar stock, the MS32-6 easily handles a wide variety of complex parts, as the machine is equipped with twelve cross slides, with two v-shaped cross slides equipped with X and Z axes located at each spindle position. C and Y axes, together with live tools, can also be implemented to allow for a broad range of machining processes, including off-center drilling, threading, contouring, hobbing and polygonal turning. All of the machines’ slides can also be alternatively configured for grooving or drilling.
Each cross slide in the MS32-6 now incorporates Index’s patented W-serration locating system that provides µm-accurate alignment of the tool holder. Coupled with the company’s newly developed quick clamping device, tools can be set up off of the machine and then quickly installed, reducing tool change times by 50 percent. Additionally, the machine incorporates the same W-serration system on its live units for drilling, milling and polygonal turning. By presetting tooling for these operations off of the machine, setup times can be reduced by up to 92 percent.
