Warning: getimagesize(https://ik.imagekit.io/agmamedia/gt/images/article_legacy_id_11821_featured_image.jpg): Failed to open stream: HTTP request failed! HTTP/1.1 404 Not Found in /home/nbd2496/geartechnology.com/article.php on line 101
Warning: Trying to access array offset on value of type bool in /home/nbd2496/geartechnology.com/article.php on line 102
Warning: Trying to access array offset on value of type bool in /home/nbd2496/geartechnology.com/article.php on line 103
Ingersoll Expands 3-Edge Insert Series
Ingersoll Cutting Tools has released 3-edged HiPosTrio inserts that feature high positive cutting geometry; ideal for small machines and gummy materials. Four insert sizes are available for complete cutter diameter, depth & density coverage. The inserts include ramping capability for cutting versatility as well as integrated wiper flats that typically produce surface finishes between 32-63 Ra. The cutters are ported with coolant. Learn more at the website below:
