Ingersoll Offers Form-Master R Series
Ingersoll Cutting Tools introduces double-sided inserts in the Form-Master R series. These all new 10 mm and 16 mm IC inserts and cutters join existing 12 mm IC products. They offer a strong anti-rotation insert clamping system with two uniquely-designed double-sided inserts (round and serrated). The serrated style insert is intended for extended reach applications, high temperature alloys, increased stability, and chip management. These inserts offer 8 and 16 cutting edges for cost-effective machining and economy. Face mill, end mills, and modular (Top-On) cutter body options are available.
