Inspection Workholding: Simply Perfect
Gleason LeCount Adjustable Expanding Mandrels offer a fast, flexible and amazingly simple solution for metrology applications where speed, accuracy and repeatability are paramount
Gleason LeCount Expanding Mandrel models accommodate an exceptionally wide range of precision clamping applications, both in the quality lab and on the production floor. Twelve standard models cover workpiece bore sizes ranging from 6.35–177.8 mm (0.25–7.00 in.) in diameter.
Keep it simple. More often than not it turns out to be the best course of action in life and on factory floors. Take, for example, Gleason LeCount Expanding Mandrels. You’ll find them in quality labs around the world, delivering reliable, repeatable workholding performance for the inspection of gears and other bore-type workpieces. Quality labs today are at the epicenter of the drive to produce increasingly complex, high-precision parts, while at the same time racing to take time and cost out of the inspection process. Counter-intuitively, perhaps, the best workholding solution to meet these ambitious new inspection requirements turns out not to be something new and more complex—but the simplest solution of all: Gleason LeCount Expanding Mandrels.
Gleason LeCount Expanding Mandrels seem almost tailor-made for the rigorous demands of today’s quality labs. They deliver the extreme accuracies required of high precision workpieces with 2.5 microns (0.0025 mm/0.0001 in.) TIR or better. Their simple design makes it easy for a technician with even minimal experience to ensure a precise, repeatable load/unload of the workpiece in a matter of seconds.
Patented Performance
While their patented design has been in existence for more than a decade, the family of Gleason LeCount Expanding Mandrels seems almost tailor-made for the rigorous demands of today’s quality labs. First, they’re capable of delivering the extreme accuracies required of today’s high-precision workpieces: 2.5 microns (0.0025 mm/0.0001 in.) TIR or better. Most importantly, their design makes it a cinch for a technician or machine operator with even minimal experience or training to ensure a precise, repeatable load/unload of the workpiece in a matter of seconds. Finally, an entire family of just 12 standard precision mandrel models spans the widest possible range of workpiece bore sizes—from 6.35 mm to 177.8 mm (0.25 in. to 7.00 in.) in diameter—thus further simplifying operation and reducing workholding investment.
Simple Perfection
Any operator will find that ‘getting it right the first time’ is a remarkably simple process using this easy-loading mandrel. The patented mandrel design incorporates three parallel expanding jaws that slide uniformly up (expanding) or down (contracting) on inclined guideways. Any workpiece bore size within its range can be accommodated by each mandrel. For example, the popular Type A mandrel, designed for an extra wide range, includes models designed for the most popular bore sizes common to most automotive transmission gears. Models are available to accommodate bore-size clamping ranges of anywhere from 12 mm to 25 mm or greater. Note that the extreme accuracy of the device over this entire adjustable clamping range does not change. It is derived from controlled, precision manufacturing that guarantees concentricity of 0.0025 mm (0.0001 in.) TIR over the entire range of the expansion.
