IPTEX 2012 Preview: Klingelnberg Booth B14
Klingelnberg will exhibit the gear measuring center P 26 at IPTEX 2012, taking place from February 9-11, at the Bombay Exhibition Center in Mumbai. This fully automatic CNC controlled machine has been designed as a compact unit for the smaller workpiece diameter range up to 260 mm. P 26 is suitable for testing spur and helical gears as well as hobs, shaper and shaving cutters, worms and worm gears, bevel gears and general deviations. Also, the machine provides precise size, form and position measurement of axially symmetrical objects. In addition to the mechanical components such as bed, workpiece rotation, the tailstock, the horizontal, vertical and tangential measuring axis and the 3-D tracer head, a 4-axis path control in conjunction with a computer ensures the functions of this machine. Preparatory works for carrying out a measurement are extremely simple with this machine concept. The quick and easy testing in combination with extensive software solutions for evaluating the measuring results contribute to reliable and efficient production processes. Industries include automotive, aviation, precision engineering, industrial construction and plant engineering; maximum outside diameter of gear is 260 mm, max. test gear weight up to 80 kg, max., vertical measuring width 400 mm, gear measurement as well as size, form and position measurement of axially symmetrical objects of all types. Versatile options for testing automotive drive elements, clutch gears, sprockets, beveloid gears as well as camshafts and crankshafts are available.
