Kapp Offers KNG 350 Flex HS at EMO 2021
The KNG 350 Flex HS is based on a compact, set-up-optimized machine concept and is intended for use in small to large-scale series production of externally geared workpieces with a diameter of up to 350 mm. The integrated loading device ensures shortest non-productive periods and can accommodate both bore parts and shaft workpieces. The new functional and ergonomic machine design paired with the innovative and user-friendly user interface KN grind supports the user during set-up and optimization of grinding projects. High-performance technology options mean that maximum precision and surface qualities can be achieved. The KNG 350 series is characterized by flexibility in processing options, loading options, automated and manual, as well as application-oriented software functions.
