Kennametal Offers New Line of PCD Tools
Kennametal has introduced a new line of PCD round tools for aluminum machining that delivers up to 10 times higher productivity than carbide tooling. The new line of drills, reamers and end mills provides exceptional tool life and wear resistance even in very abrasive aluminum alloys and are available with very short lead times.
“Our new PCD round tools line enables our customers to machine aluminum significantly faster, for greater productivity on the shop floor,” says Michael Hacker, product manager, Kennametal. “In drilling and reaming operations, these tools consistently perform at cutting speeds of up to 900 m/min (3,000 SFM). Milling operations can be performed at an incredible 6.000 m/min (20,000 SFM)—far higher than non-PCD tooling.”
With through-the-tool coolant capabilities and an MQL-ready interface, these PCD round tools are ideal for both rough and finish machining.
Extremely sharp cutting edges and low-friction rake surfaces eliminate concerns over built-up-edge. Low friction machining also produces superior surfaces in finishing operations, such as reaming. Surface roughness of Ra 0,1–0,8 μm (0.0025–0.02 μ-in) is achievable – far superior to conventional carbide tooling.
PCD grade KD1410 assures extended tool life and is particularly beneficial in the high silicon content aluminum used to make automotive parts like engine blocks or cylinder heads.
