KISSsoft Adds Plastic Materials Manager Function
It is often the case that plastics manufacturers don't provide any data that is relevant for calculations when they supply their products. Fortunately, you can now use the new "Plastics Manager" in the KISSsoft Release 03/2017 to generate plastic material files from the service life measurement data gathered in gear testing according to VDI 2736 Sheet 4 (Module ZZ6).With this calculation module, users no longer need to spend time and effort working through the test results, and it also greatly simplifies the calculation process, because all the data is brought together in a single file. With this module, you can also easily add materials to the KISSsoft database, along with the automatically generated DAT files
