Klingelnberg to Showcase Oerlikon G 30 Bevel Gear Grinding Machine at Gear Expo
Klingelnberg will be exhibiting its capabilities with a presentation of cutting-edge technology “made in Germany” in the form of the G 30 bevel gear grinding machine and the P 26 precision measuring center.
Klingelnberg, utilizes this platform for an intense professional exchange on equal footing. Not only will visitors encounter a team of Klingelnberg experts who are available for professional dialogue, but Klingelnberg will also unveil its “home-made” technology from two different business units with its G 30 bevel gear grinding machine and P 26 precision measuring center.
The Oerlikon G 30 bevel gear grinding machine continuously advances the vertical concept for grinding technology. All bevel gear machines in this series are equipped with a heat-stable, vibration-damping machine bed. An optimized axis arrangement ensures reduced approach paths and less load on the drive components – and a stiffer design of the overall system. The G 30 can be optionally equipped with a side loading door, allowing for easier loading in automatic mode using a machine integrated loading shuttle or handling robot. For series production, the machine also offers a range of process monitoring functions.
Klingelnberg has also continued to develop the P 40 measuring center. A height adjustable electric control console and the vibration isolation that can be integrated, now provide even better prerequisites for shop-floor use in the new P 40.
The fully automatic CNC-controlled precision measuring center is designed as a compact unit for the workpiece diameter range up to 400 mm. At the heart of the P 40 is an accurate, durable rotary table. Configured as a measuring axis (C axis), it provides concentric seating of the workpieces to be tested. In combination with the three linear measuring axes, tangential (X axis), radial (Y axis) and vertical (Z axis), the precision measuring centers trace and inspect the functional surfaces of gearings and general drive components in generator mode.
Measuring centers are equipped with heavy-duty, stable beds and guide bodies made of cast iron. At the same time, all bearings and guides are backlash-free at the measuring axes. These form the basis for the measuring centers' high basic mechanical accuracy. The integrated 3-D measurement system enables both discrete-point probing and scanning, continuous measured value logging. The powerful GINA software makes it possible to evaluate the results quickly and easily.
