Liebherr LC 280 Gear Hobbing Machine Updates Tested Design with New Components
The newly developed LC 280 α gear hobbing machine provides Liebherr quality with maximum flexibility and short delivery times. The new development relies on tried-and-tested know-how while at the same time including many improved components.
In recent years the gear market has been experiencing a trend towards outsourcing. As a result of this shift, many suppliers are receiving orders for the soft machining of gears. "With the LC 280 α, Liebherr has developed a new generation of gear hobbing machines for such short-term requests," reports Dr.-Ing. Hansjörg Geiser, manager, development and design, gear cutting machines. "This gear cutting machine equipped with the well-known Liebherr quality offers maximum flexibility, maximum productivity and is available to the customer at short notice."
The criteria for an investment decision regarding a new gear cutting machine are primarily quality, maximum flexibility, and at the same time maximum productivity with low procurement costs. For the user it is crucial which orders they can execute and how efficiently they can process these orders. The LC 280 α was developed precisely for these requirements. "It should offer the user the unique opportunity of being able to machine gears and shafts with a workpiece diameter up to 280 millimeters and a shaft length up to 500 millimeters. Most typical machining sizes required for a gear fall within this range," says Geiser.
Some of the tried-and-tested components were adopted in the new development and many were improved. For example, the machine base was designed with a very steep bed which prevents a deposit of chips. In addition, an optional complete stainless steel housing was integrated which reduces the thermal influence of the hot dry chips on the machine bed to a minimum.
The hob head was also redesigned for increased flexibility and productivity. "It is now possible to machine workpieces up to a module of five millimeters," explains Geiser. "The spindle speed was increased by 50 percent to 2250 revolutions per minute compared with the previous model. At the same time, the shifting length increased to 200 millimeters and the maximum tool diameter increased to 150 millimeters."
As a result of these improvements, tool life is increased considerably with the use of longer tools. Through the use of indexable carbide insert cutters, the process time for certain applications can be reduced by up to 30 percent and the tool costs per workpiece can also be lowered. As a result, the unit costs can be reduced significantly.
