"General aviation (GA) and light planes are a great way to travel and are a lot of fun. But they can be very expensive. An experimental class aircraft body can be had for $15,000, an instrument panel for $2,000. But a new engine will set you back $40,000.
"(Yet even today) the standard engine for a typical two- to four-seater is an air-cooled, four-cylinder design very similar to a 1960 VW Beetle. It's fueled by a carburetor and fired with magnetos — like your lawn mower. Yet the price for this engine is what keeps many people from flying. So we are building this advanced technology prototype to give pilots and student pilots a way out and up.
"The Double-A is a twin-engine, twin-propeller, centerline thrust engine package that fits the place usually occupied by a single aircraft engine. It uses two 130 horsepower, liquid-cooled, fuel-injected engines — one-per-prop — to provide 200 horsepower at 77 percent power for takeoff and 150 horsepower at 58 percent power for cruise. In the event of an engine failure, pilots still have 130 horsepower at their disposal.
"The engines used in the Double-A have already seen aircraft use, and are valued for their reliability and robust design in the snowmobile community, where an engine failure in the bush can easily prove fatal.
"Each engine weighs about 110 pounds dry, and a typical single-engine installation comes in around 150 pounds. We have a target weight under 350 pounds for the Double-A in running condition, compared to the 300 pound dry weight (non-running) of a 200 horsepower IO-360C.
"The first designers to pioneer this configuration (http://www.infortel.com/cozy) packaged two 100 horsepower Suzuki Swift engines weighing slightly over 400 pounds; their design is still flying today. Sixteen years of improvements in engine design allow us to shoot for a lower weight than was ever possible before.
"The Double-A package has one other important reliability feature, i.e. — it does not use an aftermarket engine control unit (ECU). A modern engine takes enormous effort — with millions of engineering man-hours to design — and too many aircraft conversions start with cutting off +/-25 percent of that design — the original ECU. Most automobile engines leave no choice, as the original ECU will not run without the car. But snowmobile engines do not have this problem and will run just fine — in or out of a sled.
"(Beyond the benefits listed above, the Double-A runs on the same automobile and small-engine gasoline you buy at the pump — not pricey aviation gas. Detailed gallons per hour versus percentage horsepower measurements will be published after the test program.)
"Also, as a used snowmobile engine costs around $4,000 — instead of $40,000 — the cost of replacement parts and repairs is greatly reduced. The closed-deck snowmobile engine used in the Double-A is quite robust; it boasts the very latest fuel-injection technology and liquid cooling. Experimental and professional, certified aviation mechanics will find the Double-A much simpler, and an absolute treat to work on, because it's tighter tolerances, modern gaskets and liquid-cooled body are much more accessible, forgiving, and ergonomically approachable than certified aviation engines.
"So, as the plans will be released for anyone to use, it's possible that a bright spark with more money and a suitable plane (but no engine) might take our work rather quickly and put it into the sky. If anyone is interested in potentially being the first to fly with the Double-A, we encourage them all to contact us (https://doubleaengine.wordpress.com)."
