LMC Workholding Releases New Face Driver
LMC Workholding recently introduced the new Neidlein FFBHZ face drivers for gear grinding, gear hobbing and gear milling, suited for high run out result operations with zero backlash. The Neidlein FFBHZ face driver design offers less downtime when changing drive diameter ranges within one face driver size.  Hydraulic compensating drive pins guarantee shear force-free clamping of workpieces with badly machined surfaces at clamping areas. The built-in hydraulic cartridge is easy to change and maintain. Neidlein face drivers quickly grip and turn a workpiece from its end, allowing the entire part to be machined in just one operation, including cutting off the ends and eliminating the need to flip the part.  Face drivers allow turning applications to have increased flexibility to lower cycle times and allow large interrupted and heavy cuts.  Neidlein face drivers offer fast set-up, quick change overs, improved part quality, reduced cost and lower maintenance. LMC Workholding engineers and manufactures high quality workholding equipment, including power chucks and cylinders, wheel chucks, face drivers and centers and steady rests.
