Low-Foaming Cutting Fluid Resists Bacterial, Fungal Growth
The KoolRite 2365 semi-synthetic cutting fluid from JTM Products, Inc. was designed for high-pressure applications that typically have foam control problems. The coolant is made with mineral oil and extreme pressure additives for use on cast iron, all steels and non-ferrous metals except magnesium.
Performance on aluminum materials has exhibited the most significant performance improvements, and the coolant performs without staining non-ferrous metals while protecting ferrous metals from corrosion. It does not remove paint or damage machines or seals. Using the JTM BioArmor technology, the Koolrite 2365 resists bacterial and fungal growth resulting in long sump life and avoiding unpleasant aromas that often result from such fluids.
