Mahr Introduces Mar4D PLQ Series
At EMO Milano 2021, Mahr presented its new Mar4D PLQ product series for the first time. The cylinder coordinate measuring machines with multi-sensor technology are optimized for use in production and in the measuring room.
Both in production and in the measuring room, complex workpieces require a highly efficient measuring machine: It should solve various measuring tasks as quickly as possible, close to production and reproducibly in one system. This is exactly what the cylinder coordinate measuring machines of the new Mar4D line do. Equipped with up to four CNC axes, optical and optional tactile sensors, as well as sophisticated monitoring systems, they reliably and precisely record 3D measured values.
Extreme flexibility in terms of workpiece size also makes a decisive contribution to a significant increase in productivity in the manufacturing environment. Depending on the machine variant and equipment, the Mar4D PLQ can inspect rotationally symmetrical workpieces up to a diameter of 200 mm, a length of 1,000 mm and a weight of 50 kg.
