Heat Treating The Gear Industry History Technical
Microsecond Heat Treatment of Gears
The performance of metal surfaces can be dramatically enhanced by the thermal process of rapid surface melting and re-solidification (RMRS). When the surface of a metal part (for instance, a gear) is melted and re-solidified in less than one thousandth of a second, the resulting changes in the material can lead to: Increased wear and corrosion resistance, Improved surface finish and appearance, Enhanced surface uniformity and purity, and Sealing of surface cracks and pores.
This article appeared in the March/April 2000 issue.
