Midwest Motion Introduces New Gearmotor
Midwest Motion Products announced the availability of the MMP-TM55-12V Gpk52-124 gearmotor.
The motor accepts any 12-volt VDC source, including battery power. The gearmotor measures 2.14" diameter by 7.7" long and has a keyed output shaft of 12 mm diameter by 25 mm long. Mounting is accomplished with four “face mount” M5 threaded holes, equally spaced.
According to Midwest Motion's press release, the output is rated for 125 in.-lb. of continuous torque at 37 rpm and 178 in.0-lbs. peak. The gearmotor weighs less than 7 lbs. and requires 7.2 amps and 12 volts to generate its full torque load. Motor windings for 24, 36, 48 and 90 volts are available.
