New Industrial Gear Oil Enhances Gearbox Durability
The new Mobilgear 600 XP Series of premium industrial gear oils was introduced by ExxonMobil.
According to the company’s press release, the gear oil is formulated to minimize wear and enhance the performance of all critical gearbox components, including gears, bearings and seals. ExxonMobil says the gear oils surpass the industry’s most demanding specifications, such as Flender BA Table 7300 A, DIN 5157 Part 3 and AGMA 9005 E02.
Mobilgear helps control micropitting and other forms of gear wear. Its balanced formulation improves bearing and corrosion protection while remaining compatible with many commonly used gearbox sealing materials. The oil is also designed to reduce the formation of oil degradation byproducts that require frequent oil changes.
